124 评论
帆软用户3fenLAunEB
java.sql.SQLRecoverableException: ORA-01034: ORACLE not available
ORA-27101: shared memory realm does not exist
Linux-x86_64 Error: 2: No such file or directory
oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java.628)
oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java.557)
oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java.552)
oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java.695)
oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java.726)
oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java.291)
oracle.jdbc.driver.T4CTTIoauthenticate.doOSESSKEY(T4CTTIoauthenticate.java.626)
oracle.jdbc.driver.T4CConnection.authenticateUserForLogon(T4CConnection.java.1013)
oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java.646)
oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java.1032)
oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java.90)
oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java.681)
oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java.602)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1657)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1723)
com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2901)
一下子可以一下子不行
0 2024-04-08 16:15
用户b8494772
设计器里面连接HANA数据库,创建数据库查询报错,这个要怎么解决
com fr. gezeral. data. Tab leDataEsrception:错误代码:11300001 数据集配置错误
SAP DBIech IDBC: [258]: insufficient privilege: Detailed info for this error can be found with guid
X
'A627492649326840AB030BBCOBCDEECD'
0 2023-12-02 14:21
yzm577664
自带的驱动不行,想换自己的驱动怎么弄
1 2022-12-27 15:17
Lily.Wang
您好,看一下这个 驱动管理-https://help.fanruan.com/finebi/doc-view-1540.html
产品里面有提示的
1 2022-12-29 17:55
yzm577664
自带的驱动不行,想换自己的驱动怎么弄
2 2022-12-27 15:17
yzm577664
自带的驱动不行,想换自己的驱动怎么弄
1 2022-12-27 15:17
