java.lang.NoSuchMethodError: org.bson.io.BasicOutputBuffer.<init>(I)V com.mongodb.internal.connection.ClientMetadataHelper.clientMetadataDocumentTooLarge(ClientMetadataHelper.java.162) com.mongodb.internal.connection.ClientMetadataHelper.createClientMetadataDocument(ClientMetadataHelper.java.126) com.mongodb.internal.connection.ClientMetadataHelper.createClientMetadataDocument(ClientMetadataHelper.java.107) com.mongodb.internal.connection.InternalStreamConnectionFactory.<init>(InternalStreamConnectionFactory.java.46) com.mongodb.internal.connection.DefaultClusterableServerFactory.create(DefaultClusterableServerFactory.java.70) com.mongodb.internal.connection.BaseCluster.createServer(BaseCluster.java.383) com.mongodb.internal.connection.SingleServerCluster.<init>(SingleServerCluster.java.58) com.mongodb.connection.DefaultClusterFactory.createCluster(DefaultClusterFactory.java.192) com.mongodb.Mongo.createCluster(Mongo.java.758) com.mongodb.Mongo.createCluster(Mongo.java.750) com.mongodb.Mongo.<init>(Mongo.java.300) com.mongodb.Mongo.<init>(Mongo.java.295) com.mongodb.MongoClient.<init>(MongoClient.java.197) com.mongodb.MongoClient.<init>(MongoClient.java.171) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.createMongoClient(null.-1) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.createMongoClient(null.-1) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.testConnection(null.-1) com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1) com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1) java.util.concurrent.FutureTask.run(FutureTask.java.266) java.util.concurrent.Executors$RunnableAdapter.call(Executors.java.511) java.util.concurrent.FutureTask.run(FutureTask.java.266) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149) java.util.co
赞 2 2023-03-30 16:00
莫名其妙的报错,还没人给解决
赞 0 2023-03-30 16:00
我也遇到了,先关闭设计器,然后删除webroot下面lib里面的 ifxjdbc-infomix.jar, 在重新启动
赞 3 2023-06-07 10:55
您好,请前往服务中心寻求技术支持。服务中心:https://service.fanruan.com/
赞 0 2023-05-29 09:50
连接报错:java.lang.NoSuchMethodError: org.bson.io.BasicOutputBuffer.<init>(I)V com.mongodb.internal.connection.ClientMetadataHelper.clientMetadataDocumentTooLarge(ClientMetadataHelper.java.162) com.mongodb.internal.connection.ClientMetadataHelper.createClientMetadataDocument(ClientMetadataHelper.java.126) com.mongodb.internal.connection.ClientMetadataHelper.createClientMetadataDocument(ClientMetadataHelper.java.107) com.mongodb.internal.connection.InternalStreamConnectionFactory.<init>(InternalStreamConnectionFactory.java.46) com.mongodb.internal.connection.DefaultClusterableServerFactory.create(DefaultClusterableServerFactory.java.70) com.mongodb.internal.connection.BaseCluster.createServer(BaseCluster.java.383) com.mongodb.internal.connection.SingleServerCluster.<init>(SingleServerCluster.java.58) com.mongodb.connection.DefaultClusterFactory.createCluster(DefaultClusterFactory.java.192) com.mongodb.Mongo.createCluster(Mongo.java.758) com.mongodb.Mongo.createCluster(Mongo.java.737) com.mongodb.Mongo.<init>(Mongo.java.317) com.mongodb.Mongo.<init>(Mongo.java.313) com.mongodb.MongoClient.<init>(MongoClient.java.328) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.createMongoClient(null.-1) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.createMongoClient(null.-1) com.fr.plugin.db.mongo.core.MongoDatabaseConnection.testConnection(null.-1) com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1) com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1) java.util.concurrent.FutureTask.run(FutureTask.java.266) java.util.concurrent.Executors$RunnableAdapter.call(Executors.java.511) java.util.concurrent.FutureTask.run(FutureTask.java.266) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.ja
赞 1 2023-02-16 11:22
11.0版 连接mongodb 5.0也出现这个问题。 备份 ifxjdbc_informix.jar 并删除该jar后,重启服务可以正常连接mongodb。该jar包位置:FineReport_11.0\webapps\webroot\WEB-INF\lib。 特别说明:删除前请备份以免影响其他业务,切记切记切记仅用于学习,未全面验证。
赞 0 2023-05-19 09:24
建议官方跟进一下,连接mongodb5.0出现这个问题。
赞 0 2023-05-17 18:14
建议前往服务中心寻找技术支持。服务中心:https://service.fanruan.com/
赞 0 2023-05-22 15:56
我也是这个错,哭~~~~~
赞 0 2023-04-20 16:21
您好,建议寻求技术支持,服务中心:https://service.fanruan.com/
赞 0 2023-05-29 11:17
这个问题解决了吗?求指教
赞 0 2023-03-30 16:02
您好,建议前往服务中心寻求技术支持,或者前往问答区提问。问答地址:https://bbs.fanruan.com/wenda
赞 0 2023-05-29 11:32
我也是报这个错
赞 0 2023-03-30 15:59
支持的mongodb版本号为多少
赞 0 2023-02-16 11:00
可以在帆软市场选择适配的版本下载~
赞 0 2023-07-17 11:31
这个插件不支持获取当前时间,不支持lookup表连接……哭了
赞 0 2022-12-08 09:14
已帮您提交了相关产品需求,如需追踪需求进度,请自行前往服务中心提交相关产品需求。建议附上需求的应用场景,以便产品团队评估。服务中心:https://service.fanruan.com/
赞 0 2023-03-02 10:40
无法使用 lookup 操作啊
赞 1 2021-12-16 13:47
有疑问您可咨询帆软技术支持~
赞 1 2022-01-05 17:05
大佬插件导入mongodb 怎么新建连接,求带
赞 1 2021-12-23 14:25
看第 2 节~
赞 1 2022-01-05 17:04
42 评论
java.util.co
莫名其妙的报错,还没人给解决
我也是这个错,哭~~~~~
这个问题解决了吗?求指教
我也是报这个错
支持的mongodb版本号为多少
可以在帆软市场选择适配的版本下载~
无法使用 lookup 操作啊
有疑问您可咨询帆软技术支持~
看第 2 节~
