帆软打开报表正常,挂载到决策系统报错
An error occurred.
Sorry,the page you are looking for is currently unavailable.
Please try again later.
If you are the system administrator of this resource then you should check the error log for details.
Faithfully yours,nginx.
怎么解决
29 评论
web页面中下拉框变成input了,无法进行选择
赞 0 2024-02-22 11:15
升级版本后出现:Could not initialize class com.fr.data.pool.MemoryConnection,这是什么情况
赞 0 2024-02-20 21:53
帆软打开报表正常,挂载到决策系统报错
An error occurred.
怎么解决
赞 1 2022-11-10 19:11
com.fr.third.javax.xml.stream.XMLStreamExceptions2 : ParseError at [row,col]:[x,xx]
这个报错根据官网帮助文档 并没有找到相关xml文件
FR version:11.0.6
https://help.fanruan.com/finereport/doc-view-1789.html
赞 0 2022-08-04 11:52
9.4有说根据不同的manager对应不同的xml文件,具体是哪个xml没找到呢?
赞 0 2022-11-02 16:15
2022-07-15 16:55:24
严重:16:55:24 FinePluginController-19-worker-1 ERROR [standard] invalid META-INF of plugin com.fr.plugin.db.es.v10
11版本安装es插件报错
赞 0 2022-07-15 17:05
你好,请您检查一下所下载的插件安装包与设计器和服务器的版本是否是同一个版本
赞 0 2022-10-09 10:11
