29 评论
帆软用户0P8SuJAa6u
web页面中下拉框变成input了,无法进行选择
0 2024-02-22 11:15
LF丶凌风
升级版本后出现:Could not initialize class com.fr.data.pool.MemoryConnection,这是什么情况
0 2024-02-20 21:53
yzmPNTcr4537744
帆软打开报表正常,挂载到决策系统报错
An error occurred.
Sorry,the page you are looking for is currently unavailable.
Please try again later.
If you are the system administrator of this resource then you should check the error log for details.
Faithfully yours,nginx.
怎么解决
1 2022-11-10 19:11
帆软用户2eK64b8F37
com.fr.third.javax.xml.stream.XMLStreamExceptions2 : ParseError at [row,col]:[x,xx]
这个报错根据官网帮助文档 并没有找到相关xml文件
FR version:11.0.6
https://help.fanruan.com/finereport/doc-view-1789.html
0 2022-08-04 11:52
Fay
9.4有说根据不同的manager对应不同的xml文件,具体是哪个xml没找到呢?
0 2022-11-02 16:15
yzmS6kf80427440
2022-07-15 16:55:24
严重:16:55:24 FinePluginController-19-worker-1 ERROR [standard] invalid META-INF of plugin com.fr.plugin.db.es.v10
11版本安装es插件报错
0 2022-07-15 17:05
Catqiu
你好,请您检查一下所下载的插件安装包与设计器和服务器的版本是否是同一个版本
0 2022-10-09 10:11
