报这个错是啥意思
ava.sql.SQLException: Error
at com.fr.third.alibaba.druid.pool.DruidDataSource.handleConnectionException(DruidDataSource.java:1875)
at com.fr.third.alibaba.druid.pool.DruidPooledConnection.handleException(DruidPooledConnection.java:137)
at com.fr.third.alibaba.druid.pool.DruidPooledStatement.checkException(DruidPooledStatement.java:100)
at com.fr.third.alibaba.druid.pool.DruidPooledStatement.executeQuery(DruidPooledStatement.java:321)
at com.fr.data.core.db.dialect.base.key.test.connection.SelectOneTestConnectionExecutor.execute(SelectOneTestConnectionExecutor.java:21)
at com.fr.data.core.db.dialect.base.key.test.connection.SelectOneTestConnectionExecutor.execute(SelectOneTestConnectionExecutor.java:13)
at com.fr.data.core.db.dialect.AbstractDialect.execute(AbstractDialect.java)
at com.fr.data.impl.JDBCDatabaseConnection.testConnection(JDBCDatabaseConnection.java:321)
at com.fr.decision.webservice.v10.datasource.connection.processor.impl.JDBCConnectionProcessor.testConnection(JDBCConnectionProcessor.java:210)
at com.fr.decision.webservice.v10.datasource.connection.processor.impl.ConnectionProcessorFactory.testConnectionWithSchemaReturn(ConnectionProcessorFactory.java:61)
at com.fr.decision.webservice.v10.datasource.connection.ConnectionService.testConnection(ConnectionService.java:95)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.fr.decision.config.ConfigInterceptor.intercept(ConfigInterceptor.java:34)
at com.fr.decision.webservice.v10.datasource.connection.ConnectionService$$EnhancerByCGLIB$$a4fd73f2.testConnection(<generated>)
22 评论
报这个错是啥意思
赞 0 2023-03-22 11:15
请问问题解决了吗? 是什么原因?
赞 0 2023-07-06 16:02
可以在社区进行提问:https://bbs.fanruan.com/wenda
赞 0 2023-07-14 16:48
根本连不上,文档驱动也没更新,帆软的文档水平真是越来越差了
赞 1 2022-04-20 11:02
您好,文档已更新
赞 0 2022-05-25 14:19
连接不上呀 项目名 域名 还有endpoint都没错 就是连不上
赞 0 2022-03-03 16:49
抱歉,文档已更新,您可以重新查看
下载驱动后放在lib里面后,连接时还是提示没有驱动呀
赞 0 2021-09-07 17:52
您好,需要重启一下工程才能生效
赞 0 2022-01-07 15:09
驱动链接不对吧,下载后是空的
赞 0 2021-01-22 15:07
您好,已更新JAR包
赞 0 2021-04-16 11:33
