连接外部oracle数据库,报sid
com.fr.third.alibaba.druid.pool.DataSourceNotAvailableException: java.sql.SQLException: Listener refused the connection with the following error:
ORA-12505, TNS:listener does not currently know of SID given in connect descriptor
项目部署后跳到一个引导页面提示外接数据库连不上,我可以保证数据库没有问题,网络没有问题,连接不能问题,mysql版本配置也没有问题,但是点击重新监测就是不行,后端报错为2024/09/04 10:01:30 http-nio-8007-exec-1 ERROR [standard] Given final block not properly padded. Such issues can arise if a bad key is used during decryption.求解答,谢谢
MYSQL连接失败:com.fr.third.alibaba.druid.pool.DataSourceNotAvailableException: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
38 评论
连接外部oracle数据库,报sid
赞 0 2025-02-17 11:33
赞 0 2024-09-04 10:06
com.fr.third.alibaba.druid.pool.DataSourceNotAvailableException: com.microsoft.sqlserver.jdbc.SQLServerException: 无法打开登录所请求的数据库 "CKD"。登录失败。 ClientConnectionId:04a49996-9238-4023-ab3d-4304f71295ad 链接SQL server数据库链接不上,来个大神帮忙看一下
赞 1 2024-01-14 22:33
赞 0 2024-01-03 09:49
配置 SQL server 数据库,导入数据时报错:migrate table com.fr.decision.authority.entity.SoftDataEntity failed
赞 0 2023-07-13 17:48
