Message Invalid character found in the request target. The valid characters are defined in RFC 7230 and RFC 3986
Description The server cannot or will not process the request due to something that is perceived to be a client error (e.g., malformed request syntax, invalid request message framing, or deceptive request routing).
26 评论
导出指定时间范围呢,怎么做
赞 0 2021-12-31 17:40
有办法实现制定列导出吗?
赞 0 2021-08-05 11:42
您好,可以尝试社区问答提问哦https://bbs.fanruan.com/wenda
赞 0 2021-08-16 16:38
步骤2.2,参数面版中添加按钮,js可以简化如下,可以不用传参
//遍历参数面板控件,获取对应的参数值。
let paramJson = {}
$.each(this.options.form.name_widgets, function (i, item) {
if (item.options.type !== 'label' && item.options.type !== 'button' && item.getName() != "PARA" && item.getName() != "SEARCH" && item.getName() != "EXPORT") {
paramJson[item.getName()] = item.getValue();
let paramJsons = $.extend({}, paramJson, {format: "excel", extype: "simple"});
var url = encodeURI('${servletURL}?viewlet=${reportName}');
FR.Msg.toast("表格下载中,请稍等");
FR.doHyperlinkByPost(url, paramJsons, "_self")
赞 2 2021-06-09 16:03
感谢
赞 1 2021-10-21 15:11
控件的颜色怎么变
赞 0 2021-08-26 16:36
不支持改变按钮颜色,但是可以自定义按钮图标来实现
赞 0 2021-10-21 15:11
控件的颜色怎么变
太棒了,可以直接用!赞
赞 0 2021-08-18 16:03
点赞~
赞 0 2021-08-16 16:42
怎么设置导出Text文件的格式 gdk/utf-8
赞 1 2021-05-11 17:13
设置格式 utf-8 / ANSI / utf-16LE / utf-16BE
赞 1 2021-05-12 13:44
使用设计器自带的,本地Tomcat可以,远程Tomcat8服务下不行,会报错
Type Exception Report
赞 0 2020-09-29 17:23
您好,服务器端JS代码中去掉最后的转码函数FR.cjkEncode(url)试一试呢
赞 0 2020-12-16 16:16
