按这个配置了报错
当前驱动加载路径下驱动未冲突
com.fr.third.alibaba.druid.pool.GetConnectionTimeoutException: wait millis 10000, active 0, maxActive 50, creating 0, createErrorCount 12
at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionInternal(DruidDataSource.java:1836)
at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionDirect(DruidDataSource.java:1483)
at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:1463)
at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:1452)
at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:100)
at com.fr.stable.pool.DataSourceAdapter.getConnection(DataSourceAdapter.java:60)
at com.fr.stable.pool.DataSourceAdapterInvertWrapper.getConnection(DataSourceAdapterInvertWrapper.java:153)
at com.fr.cbb.dialect.datasource.pool.DataSourceWrapper.getConnection(DataSourceWrapper.java:264)
at com.fr.cbb.dialect.datasource.pool.MemoryConnection.create(MemoryConnection.java:187)
at com.fr.cbb.dialect.datasource.DataSourceFactory.getConnection(DataSourceFactory.java:71)
at com.fr.data.pool.MemoryConnection.create(MemoryConnection.java:126)
at com.fr.data.auth.Authentication.authenticate(Authentication.java:50)
at com.fr.data.auth.normal.NormalAuthentication.authenticate(NormalAuthentication.java:50)
at com.fr.data.impl.JDBCDatabaseConnection.createConnection(JDBCDatabaseConnection.java:358)
at com.fr.data.impl.JDBCDatabaseConnection.testConnection(JDBCDatabaseConnection.java:331)
at com.fr.decision.webservice.v10.datasource.connection.processor.impl.JDBCConnectionProcessor.testConnection(JDBCConnectionProcessor.java:216)
at com.fr.decision.webservice.v10.datasource.connection.processor.impl.ConnectionProcessorFactory.testConnectionWithSchemaReturn(ConnectionProcessorFactory.java:64)
按这个配置了报错
当前驱动加载路径下驱动未冲突
4 评论
按这个配置了报错
当前驱动加载路径下驱动未冲突
赞 0 2024-01-13 18:13
按这个配置了报错
当前驱动加载路径下驱动未冲突
你好 请问如何连接非本地ODBC呢?非本地ODBC数据源已经配置好了,数据连接URL是jdbc:odbc:ip/name吗?
赞 0 2021-01-27 14:36
您好,请对照1.3的配置信息配置
赞 0 2021-04-30 15:48
