plugin: com.fr.plugin.assistant version: 1.2.23 update failed
2023/09/11 16:40:27 FinePluginController-8-worker-1 ERROR [standard] null
java.lang.NullPointerException: null
at com.fr.plugin.A.W.D.X(Unknown Source) ~[?:?]
at com.fr.plugin.A.P.C.E(Unknown Source) ~[?:?]
at com.fr.plugin.A.P.C.K(Unknown Source) ~[?:?]
at com.fr.plugin.A.P.C$_C.run(Unknown Source) ~[?:?]
at com.fr.plugin.A.P.C$4.run(Unknown Source) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_362]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_362]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_362]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_362]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_362]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_362]
at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_362]
2023/09/11 16:40:27 localhost-startStop-1 ERROR [standard] Job class not found, jobKey: FineOperationJobGroup.FineOperationTemplateAnalysisJob.
2023/09/11 16:40:27 localhost-startStop-1 ERROR [standard] [Schedule] Error retrieving job, setting trigger FineOperationJobGroup.FineOperationTemplateAnalysisJob1686047231970 state to ERROR
com.fr.third.v2.org.quartz.JobPersistenceException: Couldn't retrieve job because a required class was not found: com.fr.plugin.system.operation.crash.client.analysis.templates.TemplateAnalysisJob
"fanruan.log" 309L, 29465C 1,1
32 评论
赞 0 2023-09-11 16:49
不打印日志的问题 有同学解决了吗
赞 0 2023-07-26 14:55
我这边部署完后数据决策系统登录时报登录失败是在回事啊
赞 0 2023-07-11 09:02
2.3.2按照说明与jdk tomcat版本部署,为什么还会报这个错
赞 0 2023-05-20 15:57
既然是内存不足导致的, 那能否把错误提示修改一下?
实际错误原因和错误提示完全是两码事, 只看报错和日志根本不能知道问题原因, 还会引导到一个错误的排查方向...
赞 0 2022-07-25 16:09
一个前端报错,很可能对应很多个后台的问题,主要还是看个人情况
赞 0 2022-09-30 14:15
2.4部分
