The configured limit of 1,000 object references was reached while attempting to calculate the size of the object graph. Severe performance degradation could occur if the sizing operation continues. This can be avoided by setting the CacheManger or Cache <sizeOfPolicy> elements maxDepthExceededBehavior to "abort" or adding stop points with @IgnoreSizeOf annotations. If performance degradation is NOT an issue at the configured limit, raise the limit value using the CacheManager or Cache
4 评论
赞 0 2024-09-04 16:19
这个ehcache缓存falsedisableCache=true设置后,主要是体现在什么情况就不会有效了
赞 0 2024-08-21 11:46
报错,配置项不存在的报错
赞 0 2022-06-23 23:14
不支持用插件配置,直接用软件或填报的方式,在表里新增字段就行
赞 0 2022-06-24 10:08
