4 评论
兀大欣
这个11版本已经内置插件了吧
0 2024-12-17 16:24
OceanHH
是的,11.0.30及以后已经内置到常规->防宕机专项配置->x线程熔断
0 2024-12-17 17:09
yzmeBjMc2710054
安装这个插件报表直接打不开了,显示
Async support must be enabled on a servlet and for all filters involved in async request processing. This is done in Java code using the Servlet API or by adding "<async-supported>true</async-supported>" to servlet and filter declarations in web.xml.
如需访问请联系管理员
0 2023-09-14 14:26
SQLboy
其实我也是这个,report11 版本,装完就寄了 。坑啊
0 2023-12-15 10:46
