求指导,部署后查看日志报错
00:01:20 QuartzScheduler_Worker-64 ERROR [standard] com.fr.plugin.gauge.custompie.PieChartWithCustomPane
java.lang.ClassNotFoundException: com.fr.plugin.gauge.custompie.PieChartWithCustomPane
at com.fr.invoke.ClassFactory.classForName(Unknown Source)
at com.fr.stable.StableUtils.classForName(Unknown Source)
at com.fr.chart.chartattr.ChartCollection.readXML(Unknown Source)
at com.fr.form.ui.ChartEditor.readXML(Unknown Source)
at com.fr.stable.xml.XMLableReader.readXMLObject(XMLableReader.java:410)
at com.fr.form.ui.WidgetXmlUtils.readWidget(Unknown Source)
at com.fr.form.ui.container.WTitleLayout$3.readXML(Unknown Source)
at com.fr.stable.xml.XMLableReader.readXMLObject(XMLableReader.java:393)
at com.fr.form.ui.container.WTitleLayout.readXML(Unknown Source)
at com.fr.form.ui.widget.CRBoundsWidget.readXML(Unknown Source)
at com.fr.form.ui.container.WLayout.readXML(Unknown Source)
at com.fr.form.ui.container.WSortLayout.readXML(Unknown Source)
at com.fr.form.ui.container.WAbsoluteLayout.readXML(Unknown Source)
at com.fr.form.ui.container.WAbsoluteBodyLayout.readXML(Unknown Source)
报错
Caused by: com.sun.tools.attach.AgentLoadException: Failed to load agent library
at sun.tools.attach.LinuxVirtualMachine.execute(LinuxVirtualMachine.java:224)
at sun.tools.attach.HotSpotVirtualMachine.loadAgentLibrary(HotSpotVirtualMachine.java:58)
at sun.tools.attach.HotSpotVirtualMachine.loadAgentPath(HotSpotVirtualMachine.java:88)
... 25 more
用root权限启动后,日志报错507:
[root@localhost logs]# cd ../bin
[root@localhost bin]# ./startup.sh &
[1] 3363
[root@localhost bin]# Using CATALINA_BASE: /home/admin/tomcat
Using CATALINA_HOME: /home/admin/tomcat
Using CATALINA_TMPDIR: /home/admin/tomcat/temp
Using JRE_HOME: /home/admin/tomcat/jre
Using CLASSPATH: /home/admin/tomcat/bin/bootstrap.jar:/home/admin/tomcat/bin/tomcat-juli.jar
Using CATALINA_OPTS: -Djava.awt.headless=true
Tomcat started.
[1]+ Done ./startup.sh
[root@localhost bin]# cd ../logs
[root@localhost logs]# tail -f catalina.out
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
/home/admin/tomcat/bin/catalina.sh: line 507: /home/admin/tomcat/jre/bin/java: Permission denied
143 评论
求指导,部署后查看日志报错
赞 0 2021-06-15 10:23
报错
... 25 more
赞 0 2021-05-26 18:02
免费用户到https://bbs.fanruan.com/wenda问答问下呢;付费用户联系下技术支持呢:技术支持联系方式:QQ「800049425」、电话「400-811-8890」
赞 0 2021-08-02 14:23
我司技术支持服务渠道已转移至服务中心,请前往服务中心联系技术支持。服务中心:https://service.fanruan.com/
赞 0 2022-12-14 16:25
3.1 模板预览报错,使用了方案1和方案二,依然出现这个空指针异常,环境是CentOS8 mini安装
赞 0 2021-05-12 15:06
用root权限启动后,日志报错507:
[1] 3363
Tomcat started.
赞 0 2021-04-23 16:08
用方案二替换后启动报错
方案二替换文件后,启动tomcat服务日志报错
admin@localhost bin]$ ./startup.sh
touch: cannot touch '/home/admin/tomcat/logs/catalina.out': Permission denied
/home/admin/tomcat/bin/catalina.sh: line 507: /home/admin/tomcat/logs/catalina.out: Permission denied
[admin@localhost bin]$
赞 0 2021-04-23 16:03
