你写清楚啊只有11的才能通过驱动管理上传,10的只能自己手动放到目录里
赞 0 2024-04-24 15:35
10.0的怎么做填报?这个模版是11.0的
赞 0 2024-03-20 11:17
上传完驱动,连接报这个错误怎么解决 当前驱动加载路径:D:\02-work_software\FineReport_11.0\webapps\webroot\WEB-INF\lib\postgresql-42.5.4.jar org.postgresql.util.PSQLException: Unable to parse URL jdbc:postgresql://localhost:port/databaseName org.postgresql.Driver.connect(Driver.java.274) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1666) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1732) com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2907)
赞 0 2024-02-01 16:59
上传完驱动,连接报这个错误怎么解决 当前驱动加载路径:D:\02-work_software\FineReport_11.0\webapps\webroot\WEB-INF\lib\postgresql-42.5.4.jar org.postgresql.util.PSQLException: ��������: ���ݿ� "public" ������ org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java.2676) org.postgresql.core.v3.QueryExecutorImpl.readStartupMessages(QueryExecutorImpl.java.2788) org.postgresql.core.v3.QueryExecutorImpl.<init>(QueryExecutorImpl.java.174) org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java.313) org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java.54) org.postgresql.jdbc.PgConnection.<init>(PgConnection.java.253) org.postgresql.Driver.makeConnection(Driver.java.434) org.postgresql.Driver.connect(Driver.java.291) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1666) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1732) com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2907)
赞 0 2024-02-01 16:57
忽略这条
赞 1 2024-02-01 17:00
数据库连接失败,当前驱动加载路径:D:\360安全浏览器下载\FineReport_11.0\webapps\webroot\WEB-INF\drivers\pg驱动\postgresql-42.7.0(1).jar,当前驱动加载路径下驱动未冲突,怎么解决
赞 0 2023-12-05 21:03
解决了吗请问,如果解决了,是怎么解决的
赞 0 2024-01-15 15:16
82 评论
上传完驱动,连接报这个错误怎么解决
上传完驱动,连接报这个错误怎么解决
忽略这条
解决了吗请问,如果解决了,是怎么解决的
